Page 4 of 75
FirstFirst ... 2 3 4 5 6 14 54 ... LastLast
Results 91 to 120 of 2222
  1. DECEASED
    Jun 2009
    Heaven
    Originally Posted by tnti View Post
    I do not speak English
    Then use Google Translator, at least.
    FWIW, tebasuna51 lives in Spain and is a decent programmer too, even though his English sucks terribly
  2. Originally Posted by DarrellS
    Hard to produce a working file when every encoder uses a different command line. Every file I try to create ends with a crash in the encoder and the out put, although it kind of plays (corrupt frames) crashes every player.
    Working sample commands would be nice for each encoder so we can tell if it's our command line or our system that refuses to create a working file.
    I just formatted a spare drive and will install a back up image of my operating system when I knew everything was working fine. I've installed and uninstalled so much crap the last couple of months trying to get 265 and VP9 to work that I don't know how much damage I've done to the operating system.
    Maybe XP with 4GB of memory and a Q6600 cpu is just not good enough to create a working file.
    @DarrellS
    Have you seen the members of JCT-VC laughing on your back? Never mind they did not see someone laughing at them either. Do Not Mind if you are one of them.
    Personally, I would like to THANK YOU! sincerely, for bringing it to notice.
    My roll is very, very limited to clap as under:
    Jul 2013
    Spain
    Compiled in Virtual Studio 2008 SP1 32 Bit up-to-date whith commit 0388013
    No, has the problem of "The program has stopped working"
    x265 [info]: HEVC encoder version 0.3+173-03880135c31b
    x265 [info]: build info [Windows][VS 1500][32 bit] 8bpp
    x265 [info]: detected SIMD architectures SSE2 SSE3
    x265 [info]: performance primitives: intrinsic assembly
    Mediafire: x265 version 0.3+173-03880135c31b
    @ El Heggunte
    Can you please try it on win xp?
  4. Banned
    Nov 2005
    Originally Posted by El Heggunte View Post
    Yet another "and-oh-BTW" ,
    Donald Graft is in his "pre-menstrual princess blues" days again
    { http://forum.doom9.org/showthread.php?p=1639339#post1639339 }
    Originally Posted by neuron2
    Isn't x265 GPL? If so you have to supply the source code as well, per GPL. Failure to comply will result in your posts being deleted. Also, no foreign languages in your signature. Thank you.
    he has got to be one of the biggest pieces of shit the world has ever seen. i sometimes wonder if donny/neuron2 is really doom9, otherwise i can't understand why he's even allowed on that board much less a mod.
  5. DECEASED
    Jun 2009
    Heaven
    @ El Heggunte
    Por supuesto que sí
    Originally Posted by Trepack View Post
    Compiled in VIRTUAL Studio 2008 SP1 32 Bit up-to-date whith commit 0388013
    VIRTUAL Studio? I see, this explains it all
  6. DECEASED
    Jun 2009
    Heaven
    Here goes an idea that I cannot test, since I don't have Visual Studio:
    In the file wavefront.cpp, there exist the following lines:
    #if _WIN32_WINNT <= _WIN32_WINNT_WINXP
    /* Windows XP did not define this intrinsic */
    FORCEINLINE LONGLONG _InterlockedOr64(__inout LONGLONG volatile *Destination,
                                          __in    LONGLONG           Value)
        LONGLONG Old;
        do
            Old = *Destination;
        while (_InterlockedCompareExchange64(Destination, Old | Value, Old) != Old);
        return Old;
    #define ATOMIC_OR(ptr, mask)            _InterlockedOr64((volatile LONG64*)ptr, mask)
    #if defined(__MSC_VER) && !defined(__INTEL_COMPILER)
    #pragma intrinsic(_InterlockedCompareExchange64)
    #endif
    #else // if _WIN32_WINNT <= _WIN32_WINNT_WINXP
    #define ATOMIC_OR(ptr, mask)            InterlockedOr64((volatile LONG64*)ptr, mask)
    #endif // if _WIN32_WINNT <= _WIN32_WINNT_WINXP
    So, I suppose, removing the lines above from the file
    should make the MSVS x265.exe compatible with Windows XP
  7. Banned
    Nov 2005
    does anyone know how to compile ffmpeg from source on windows? it seems someone has created a patched ffmpeg build that supports x265, at least a slightly older x265 build:
    http://code.google.com/p/x265/downloads/list
    i have no idea how to build it, if someone can build it and it works as advertised i'm going to try to put together a simple gui using Lazarus for people to play around with.
    edit: i just noticed that there is a binary version of it on that page, testing it now.
    Aug 2013
    China
    The two are not the same people developed X265
    gcc compiler X265 can not be used under WIN7
    https://bitbucket.org/multicoreware/x265/wiki/Home =Steve Borho
    http://code.google.com/p/x265/downloads/list = Chinese
  9. DECEASED
    Jun 2009
    Heaven
    Now I think this piece of code could be simply fixed, instead of merely deleted
    If I am not misunderstanding everything, that Interlocked-whatever-thing *can* be used with Windows XP,
    according to the URL below:
    http://msdn.microsoft.com/en-us/library/ttk2z1ws(VS.80).aspx
    There are several variations on _InterlockedCompareExchange that vary based on the data types they involve and whether processor-specific acquire or release semantics is used.
    While the _InterlockedCompareExchange function operates on long integer values, _InterlockedCompareExchange16 operates on short integer values and _InterlockedCompareExchange64 operates on 64-bit integer values. Because _InterlockedCompareExchange64 uses the cmpxchg8b instruction, it is not available on pre-Pentium processors, such as the 486.
    Aug 2013
    China
    @ El Heggunte
    Know how to solve the problem by closing with control + c to windows detects an error in the application as well as when the program ends encode?
    Is a program problem?
    With the most recent commits, yes, it seems there is a problem in them.
    There is no --gops switch in the new version of x265.
    The HEVC file generated by the new version of x265 cannot be decompressed by the Lentoid decoder and I have already reported this problem to Strongene.
    I've just run a test encode with the latest "stable" build of x265 (commit 48c6641), and the HEVC file it produced is decoded fine by hevcdecfltr.dll 2.0.1.11
    Open --no-wpp can decode HEVC
    Inefficient after the closure under
    Nov 2002
    I guess it's encoding. It's been running for about an hour and a half and is at 0% but it's using all four cores at 100% and the output file is almost 220MB. I'm usimg El Heggunte's command from post #22 in build x265-v0.3-161. I can't run 173 because I'm running XP Pro.
  12. Banned
    Nov 2005
    if you download the sources for both and look at the credited authors Win Chen seems to have started the latter and his work has been absorbed into the former, i don't think the output of each would be too different at this early stage of development.
  13. DECEASED
    Jun 2009
    Heaven
    To whom this may interest:
    Originally Posted by Steve Borho
    Min Chen is the fellow who first wrote an HEVC encoder named x265. We have hired him to work with us. He mostly uses XP, VC9, and/or the Intel C compiler.
    Nov 2002
    Installed back up image from June 8th but it didn't make any difference. Encoder still crashes at end of file creation and I get a corrupt file.
    (C) Copyright 1985-2001 Microsoft Corp.
    C:\Tools\x265-v0.3-161>x265 --width 1920 --height 1080 --rate 14.985 --me 1 --fa
    st-cbf --no-weightp --no-weightbp --hash 0 --max-merge=1 --no-tskip --tu-inter-d
    epth=2 --tu-intra-depth=1 --no-rdo --no-rdoq --keyint 24 --qp 24 -o C:\Tools\x26
    5-v0.3-161\video.hm10 C:\Tools\x265-v0.3-161\video.yuv
    yuv [info]: 1920x1080 14Hz, frames 0 - -303 of -302
    x265 [info]: detected SIMD architectures SSE2 SSE3 SSSE3
    x265 [info]: Main profile, Level-4 (Main tier)
    x265 [info]: thread pool with 4 threads, WPP enabled
    x265 [info]: CU size : 64
    x265 [info]: Max RQT depth inter / intra : 2 / 1
    x265 [info]: ME method / range / maxmerge : hex / 64 / 1
    x265 [info]: Keyframe Interval : 24
    x265 [info]: WaveFrontSubstreams : 17
    x265 [info]: QP : 24
    x265 [info]: enabled coding tools: rect amp cfm no-rdo sao sao-lcu sign-hide
    x265 [info]: frame I:45 kb/s: 54350.07 PSNR Mean: Y:44.700 U:40.267 V:40.629
    x265 [info]: frame P:1033 kb/s: 29999.87 PSNR Mean: Y:41.335 U:37.276 V:38.905
    x265 [info]: global: kb/s: 31016.35 PSNR Mean: Y:41.476 U:37.401 V:38.977
    > x265.exe!00409bc0()
    [Frames below may be incorrect and/or missing, no symbols loaded for x265.exe]
    x265.exe!00407d19()
    x265.exe!00733b9f()
    kernel32.dll!7c817610()
    x265.exe!00734219()
    ntdll.dll!7c91003d()
    msvcrt.dll!77c39f8e()
    x265.exe!006bfcf3()
    x265.exe!006ba178()
    x265.exe!006ba1d6()
    x265.exe!007224c8()
    x265.exe!006f53bc()
    x265.exe!006d5185()
    x265.exe!00723935()
    x265.exe!006b8d9f()
    x265.exe!00401402()
    x265.exe!00401402()
    ntdll.dll!7c90d89c()
    kernel32.dll!7c80a4cb()
    kernel32.dll!7c817067()
    I give up. Someone PM me when anyone gets a working up to date ffmpeg with x265 support. Preferrably an official release but any working ffmpeg that supports hm10 and not hm6 or hm7.
  15. Banned
    Nov 2005
    good for him, i've been looking over the code he wrote, he's a damn good programmer.
  16. Member vhelp's Avatar
    Mar 2001
    New York
    fyi..i'm pretty much out of contributions to this thread with my poor system specs and many problems.
    but, how many frames are you encoding ?
    can you try a lower resolution ? don't tax yourself by using the max resolution (it will ware you out) wait till later when you've found a proven system of steps.
    and, have you treid jeeb's x265 ? i have not had any problems with it so far, but i was only using 720x480.
  17. Banned
    Nov 2005
    just out of curiosity, what are you using as sources for your test x265 encodes?
  18. Member vhelp's Avatar
    Mar 2001
    New York
    all "source" videos to be encoded should be prepped to raw YUV format, assuming film:
    ffmpeg -i "video.avs" -s 720x480 -r 24000/1001 -f rawvideo -pix_fmt yuv420p -y "video.yuv"
    if you want to prep for a short sequence to make testing go faster, add -frames x
    ffmpeg -i "video.avs" -s 720x480 -r 24000/1001 -f rawvideo -pix_fmt yuv420p -frames 30 -y "video.yuv"
    will create a 30 frame raw .yuv video file.
    then, feed that (the raw video.yuv file) into either ffmpeg (libx265) or x265.exe
    Nov 2002
    I've tried standard resolution, 960x528, 1280x720 and 1920x1080. My input files are not very big. They're from animations that last about 20 seconds, anywhere from 1fps, 5fps, 14.9fps, 24.976fps to 29.970fps. I've used Gif Movie Gear, Virtualdub with ffdshow and ffmpeg to convert to YUV. I used a yuv.avi with the patched ffmpeg that seemed like it worked but nothing bwould play it. I tried all of the above with all the different x265.exe files and all the different commands that I've found.
    I think there might be something wrong with the input files but how would I know? I only found one free yuv player and nothing plays in it.
    The only thing I've gotten to work that I saw an output file that played was the first Tappencoder (which I assumed these were built off of) and the Strongene-Lentoid encoder which was much faster and output a good picture. Strange thing was that I did not have to use YUV with the Lentoid encoder. It accepted almost every file I threw at it except newer DivX.
    Nov 2002
    I'll try those commands. The one I got from ffmpeg tutorial was a lot different. Wait a minute. You're using avs. You can't just feed an uncompressed avi to ffmpeg? What does your avisynth script look like? It would be nice if there was a guide in the first post so we didn't have to dig through threads all over the internet trying to find the answers.
    How do you create a y4m file so that you don't have to add frame width height and frame rate to the command?
  21. DECEASED
    Jun 2009
    Heaven
    avs2yuv input.avs -o output.y4m
    http://komisar.gin.by/tools/avs2yuv/
  22. Member
    Jul 2013
    Spain
    You can also...
    avs2pipe video video.avs > video.y4m
    http://doobrymedia.com/avs2pipe-0.0.3.zip
    The encoder accepts YUV or Y4M files as input.  Picture size and frame rate are automatically
    detected for Y4M files, but must be specified in the command-line when encoding YUV files.
    For playback .y4m ffplay,Mplayer,VLC...
    For playback .hm10 Strongene_Lentoid_HEVC_Decoder_v2.0.1.11_2013_07_2 4+MPC Media Player Classic
  23. DECEASED
    Jun 2009
    Heaven
    Today we present HEVC-in-ASF for your pleasure
    Format                                   : Windows Media
    File size                                : 10.4 MiB
    Duration                                 : 1mn 31s
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 951 Kbps
    Maximum Overall bit rate                 : 959 Kbps
    Encoded date                             : UTC 2013-08-07 08:38:09.620
    Video
    Format                                   : HEVC
    Format/Info                              : High Efficiency Video Coding
    Codec ID                                 : HEVC
    Duration                                 : 1mn 31s
    Bit rate mode                            : Variable
    Bit rate                                 : 736 Kbps
    Width                                    : 640 pixels
    Height                                   : 480 pixels
    Display aspect ratio                     : 4:3
    Frame rate                               : 23.976 fps
    Bits/(Pixel*Frame)                       : 0.100
    Stream size                              : 8.02 MiB (77%)
    Audio
    Format                                   : AC-3
    Format/Info                              : Audio Coding 3
    Codec ID                                 : 2000
    Duration                                 : 1mn 31s
    Bit rate mode                            : Constant
    Bit rate                                 : 192 Kbps
    Sampling rate                            : 48.0 KHz
    Bit depth                                : 32 bits
    Stream size                              : 2.09 MiB (20%)
  24. DECEASED
    Jun 2009
    Heaven
    @ Trepack: ffplay should be used "as a last resource" only, because it sux suxx suxxx
    Mplayer is much better IMNSHO.
  25. Member
    Jul 2013
    Spain
    If,it is but give to play
  26. DECEASED
    Jun 2009
    Heaven
    Fortunately foxyshadis has chimed in and made things crystal-clear:
    ... the GPL actually only requires "source code on request"; pointing to the exact git revision on bitbucket would satisfy the requirement, unless you applied any patches.
    http://forum.doom9.org/showthread.php?p=1639556#post1639556
    And oh BTW again , just wondering why the hell none of the NORMAL moderators @ Doom9 has ever dared to strike and ban Donald Graft Seriously, it's not that difficult to find MANY posts where the Great Fruitcake does violate this or that forum rule...
    But of course, I had already forgotten, some forum members are more equal than others
  27. Member vhelp's Avatar
    Mar 2001
    New York
    @DarrellS
    i use command line script to prep the raw yuv file. i don't include audio, for obvious reasons though some are fully aware of my muxing issues with it. plus, its simple. we just want to see some video. audio can be added later.
    the avs script can be anything, really. uncomp, comp, mpeg, xvid, avi, yuy2, yv12, and so on, ffmpeg will convert it to the yuv format (command line above) and converts it to the i420 sample format using 16..235 levels, automatically.
    but, to verify that it converted to a working raw yuv, you play it through a yuv player, but the ones i had at the time did not play them bc they did not offer manual dimension change, i think. anyway, i found an older one and d/l'ed it and it worked fine, but does crash on occasion or garble up the rw/fw/play/stop button at the bottom. so its a little buggy. another reason i want to create my own basic player/viewer. no audio. just video is all i need. just something that i can throw into via drag/drop quickly since i'm maining encoding to my usb member stick which is a it slow at times. so a (working) custom player would be nice, and that's what i'm working on, in between other jobs.
    another way you can test the playback (creation) of raw yuv files is to use avisynth scripts. i was using this for a while but like i said, i prefer the qucker drag/drop method. specially if i have a bunch i just want to drag/drop/view quickly in a folder when i'm searching for something to work with. the script below was used in many encoding projects, hence the many lines of options. snip what you don't need. i prefer to keep all lines but remark out what i don't use since its much quicker to change that aspect of the script. the script is not bible, customize in your own way to sute your needs.
    an alternate method of raw yuv file playback/viewer through avisynth:
     x = "h:\video.yuv"
     LoadPlugin("c:\plugins\rawsource.dll")
    # RawSource(x, width=1920, height=1080, pixel_type="i420") # way too slow for x265 encoding on my system
    # RawSource(x, width=1280, height= 720, pixel_type="i420") # way too slow for x265 encoding on my system
    # RawSource(x, width= 720, height= 480, pixel_type="yv12")
    # RawSource(x, width= 352, height= 240, pixel_type="i420")
    # RawSource(x, width= 352, height= 288, pixel_type="i420")
    # RawSource(x, width= 720, height= 480, pixel_type="i420")
      RawSource(x, width= 720, height= 480, pixel_type="YVYU")
    # AVIsource(x, pixel_type="yuy2") # YUV420P
    # AVIsource(x, pixel_type="yv12") # YUV420P
    # swapuv # sometimes things don't work correctly and i have to swap the u/v values
    # assumefps(24) # sometimes things work correctly and i have to add this
      convertToyv12
    # trim(0,60)
    ok, i'm rushing out..see you later..
  28. Member ozok's Avatar
    Oct 2011
    Turkey
    @deadrats how did your experiment with ffmpeg build go? I was also planning to write a simple GUI for x264, I thought I'd look at this thread to see if anyone was planning to do it.
  29. Member vhelp's Avatar
    Mar 2001
    New York
    from my experience with ffmpeg (libx265) i was not able to decode (play/view) it back. the x265 encoding part of it went pretty fast on my slow computer. that was (or should be) a dead giveaway that it will not work as expected. i mean the same test clips i threw in other encoders that took 10 minutes or longer only took less than a minute to encode with the ffmpeg (libx265) build. even the strongene lentoid was a lot longer encoding time. anyway. most of the original decoding/muxing tools for the .bin creation would not accept it or would choke on it, including the spcecial modified mkvtoolnic by divx. well, so far it is still not working. me thinks it is an incomplete build, imo. a gui is easy to create for all command line tools (i have several versions of my own for them) but would be frustrating to create for those command line tools that don't work!
  30. Member ozok's Avatar
    Oct 2011
    Turkey
    I see. I had thought people might find it usefull since many seem to be eager to test x265.
